• Online Store
BODY MOUNT SPACER – 1 inch high
Store/MISCELLANEOUS
$8.00
Hole Size
BODY MOUNT SPACER – FORD 1″ HIGH x 1″ HOLE
A NeratDemo.com “ORIGINAL”, FIRST DEVELOPED BY BRIAN IN 2001 TO BE USED ON HIS OWN DERBY CARS!
OUR BODY MOUNT SPACER BUSHINGS ARE MADE OF STEEL SO THEY WON’T CRUSH OR BREAK. THE MACHINED STEP SITS PERFECTLY IN YOUR FRAME TO PROVIDE THAT SPACE BETWEEN THE CAR FRAME AND BODY.
FRAME TYPE: FORD,GM
Store/MISCELLANEOUS
Report abuse
